Use the port command to set the location-based server port address. The port command is accessible from the lbs context of the CLI.
| 0-65535 | Specifies the port address of the location-based server. Enter at least 2 digits (for example, 06 for port 6). |
This command is visible only if a location-based service has been enabled via the service command.
The default port address is 00
The following example sets the port address of the Ekahau server to 06:
EWC.extremenetworks.com:lbs# service ekahau EWC.extremenetworks.com:lbs# port 06
Print
this page
Email this topic
Feedback
