Use the use-policy-zone command to enable or disable a policy zone at a called station. The use-policy-zone command is accessible from the wlan:<WLAN-service-name>:auth context of the CLI.
After you run the use-policy-zone command, run the apply command to implement the changes.
| enable | disable | Enables or disables the policy zone on this WLAN. |
The following example enables the policy zone on the test WLAN:
EWC.extremenetworks.com:wlans:test:auth# use-policy-zone enable EWC.extremenetworks.com:wlans:test:auth# apply EWC.extremenetworks.com:wlans:test:auth# show use-policy-zone Use policy zone name in Called-Station-Id: enable
Print
this page
Email this topic
Feedback
