Use the fqdn command, within context wlan:<WLAN-service-name>:auth:captiveportal, to replace the Gateway IP address with a Fully Qualified Domain Name (FQDN).
After you run the fqdn command, run the apply command to implement the changes.
| value_string | Specifies a domain name |
| none | Specifies that the Gateway IP address is not replaced with a FQDN |
The guestportal, internal, or splash authentication mode must be set for this command to be available. For more information, see mode.
The following example replaces the Gateway IP address with a domain name:
EWC.extremenetworks.com:vnsmode:CNL-7-CP:auth:captiveportal# fqdn cp.siemens.com EWC.extremenetworks.com:vnsmode:CNL-7-CP:auth:captiveportal# apply
Print
                        this page
Email this topic
Feedback
