This section describes commands used to define and configure Virtual Network Services (VNS) for the network. These commands are located in the vnsmode context of the CLI. Execute the vnsmode command at the root level to enter vnsmode context.
All CLI commands cache changes. For this reason, sometimes when you make a change in a particular context, the change may not be visible immediately. If this happens, you must exit and re-enter the context in order to ensure that the database is synchronized with the latest change.
The following commands are available in the vnsmode context:
Print
this page
Email this topic
Feedback
