Use the tx_min_power command to specify the minimum Tx power level. The tx_min_power command is accessible from all radio contexts of the CLI. The tx_min_power is available only when Auto Tx Power Ctrl (ATPC) is enabled.
| value | Specifies the value in dBm. |
The following example specifies the minimum Tx power level to 8 dBm:
EWC.extremenetworks.com:ap:defaults:ap37xx:radio1# tx_min_power 8
Print
                        this page
Email this topic
Feedback
