Use the uplink command to manage the uplink policer action for this WLANS. The uplink command is accessible from the wlan:<WLAN-service-name>:qos-policy context of the CLI.
After you run the uplink command, run the apply command to implement the changes.
| delts | Specifies that TSPEC violations will end when they are discovered. This action deletes the TSPEC. |
| do-nothing | Specifies that TSPEC violations are allowed to continue when they are discovered. Data transmissions will continue and no action is taken against the violating transmissions. |
This command is only active if the Video and Voice Admission Control is set to enable. See video-admission-control and voice-admission-control.
The following example defines the uplink policer action to end TSPEC violations by deleting the TSPEC for the CNL-7-CP WLANS:
EWC.extremenetworks.com:wlans:CNL-7-CP:qos-policy# uplink delts EWC.extremenetworks.com:wlans:CNL-7-CP:qos-policy# apply
Print
this page
Email this topic
Feedback
