Use the authset command to set authentication server information. The authset command is available from the login:auth context.
| server_name | Specifies a valid RADIUS server name |
| port | Specifies the RADIUS server port |
| retry_value | Specifies the number of times to attempt to access the RADIUS server |
| time_out | Specifies the time in seconds to wait for a response from the RADIUS server before trying again |
| NAS_IP | Specifies the NAS IP address |
| nas_string | Specifies the Network Access Server (NAS) Identifier |
| PAP | CHAP | MS-CHAP | MS-CHAP2 | Specifies the Authentication Protocol |
The following example specifies the authentication server information:
EWC.extremenetworks.com:login:auth# authset Radius 1812 3 5 192.168.4.112 NAS MS-CHAP
Print
this page
Email this topic
Feedback
