cdr
Use the cdr command to enable or disable the collection of Wireless Controller accounting information. The cdr command is accessible from the wlan:<WLAN-service-name>:auth context of the CLI.
After you run the cdr command, run the apply command to implement the changes.
cdr enable | disable
Parameters
enable | disable Specifies to enable or disable the collection of Wireless Controller accounting information
Usage
The cdr command is available in all authentication modes. For more information, see mode.
The following example enables the collection of Wireless Controller accounting information:
EWC.extremenetworks.com:wlans:test:auth# cdr enable
EWC.extremenetworks.com:wlans:test:auth# apply
EWC.extremenetworks.com:wlans:test:auth# show cdr
Collecting accounting information of Wireless Controller: enable
