Use this command to enable or disable the band preference feature for all APs in a radio type load group. The bandpreference command is accessible from the ap:load-groups:<named-load-group> context of the CLI, for the radio type of load group.
| enable | Enable band preference steering. |
| disable | Disable band preference steering. The default condition is disabled. |
This example enables band preference steering for the radio load group named radiogroup1:
EWC.extremenetworks.com:ap:load-groups:radiogroup1# bandpreference enable
Print
                        this page
Email this topic
Feedback
