This section describes commands used to define and configure topology objects used by policy and VNS objects. These commands are located in the topology context of the CLI. Execute the topology command at the root level to enter topology context.
All CLI commands cache changes. For this reason, sometimes when you make a change in a particular context, the change may not be visible immediately. If this happens, you must exit and re-enter the context in order to ensure that the database is synchronized with the latest change.
The following commands are available in the topology context:
Print
this page
Email this topic
Feedback
