Use the egress-vlans command to add, update, or delete static untagged VLANs (topologies) on the egress list of this role.
The egress-vlans command is accessible from within the role:<named-role> context.
| add | update | delete | Specifies whether the specified VLAN (topology) is to be added, deleted, or updated on an egress list for this role. |
| topology-name [, topology-name] | Specifies the name of a topology to be added, deleted, or updated on the VLAN egress list. Multiple VLANs may be included in a comma-separated list. |
The following example adds VLANs 2111, 2121, and 2101 to the egress-list of the Auth role:
EWC.extremenetworks.com:role:Auth# egress-vlans 2111,2121,2101 EWC.extremenetworks.com:role:Auth# apply
The following example deletes VLAN 2111 from the egress-list of the Auth role:
Print
this page
Email this topic
Feedback
