Use the fast-transition command to enable and disable 802.11r Fast Transition. The fast-transition command is accessible from the wlan:<WLAN-service-name>:priv context of the CLI.
| enable | disable | Enables or disables 802.11r Fast Transition. |
The following example enables 802.11k Fast Transition support on the WLAN service:
EWC.extremenetworks.com:wlans:AZ-723-WLAN1:priv# fast-transition enable
Print
this page
Email this topic
Feedback
