Use the ssh command to enable or disable SSH.
The ssh command is accessible from the ap:<serial> and all ap:defaults contexts of the CLI.
| enable | disable | Enables or disables SSH on the specified AP. |
By default, SSH is enabled. If you disable SSH, you can still retrieve AP traces from the controller through SFTP.
The following command disables SSH on AP 0500008043050236:
EWC.extremenetworks.com:ap:0500008043050236# ssh disable
Print
this page
Email this topic
Feedback
