Use the rateprf-out command to configure an already existing rate profile for an outbound rate limit for CoS. The rateprf-out command is accessible from the cos:<named-cos> context.
| profile | Specifies the egress rate profile to configure for this cos:<named-cos> context. |
| none | Specifies that the egress rate profile will not be used for this wlans:default-cos context. |
Refer to rateprofile for rate profile configuration information.
The following example configures the my-cos CoS with the DocRateOut egress rate profile:
EWC.extremenetworks.com:cos:my-cos# rateprf-out DocRateOut EWC.extremenetworks.com:cos:my-cos# apply EWC.extremenetworks.com:cos:my-cos# show Assigned topology: guestPortal Ingress rate profile: DocRateIn Egress rate profile: DocRateOut Enable AP filtering: disable Synchronize: enable EWC.extremenetworks.com:cos:my-cos#
Print
this page
Email this topic
Feedback
