authkey
Use the authkey command to set the password used for authentication. Use the no form of the command to clear the password.
Authentication must be configured to use a password before this command can be used. For more information, see authtype.
authkey password
no authkey
Parameters
password Specifies the password used for authentication
The following example sets an authentication password:
EWC.extremenetworks.com:ip:ospf:ospfinterface:top1# authkey hello123
