Use the traceroute command to perform a traceroute to a specified IP address. Optionally, you can specify the source interface.
| source-interface | Keyword indicating that a source interface will be specified. |
| name | Identifies the source interface by name. The names are platform specific. You can use the show topology command to display a list of interfaces. |
| number id | Identifies the source interface by number. The numbers are platform specific. |
| IP Address | Specifies an IP address. The IP address can be either IPv4 A.B.C.D or IPv6 A:B:C:D:E:F:G:H format. |
The following example performs a traceroute to a specified IP Address:
EWC.extremenetworks.com# traceroute 68.142.226.40 traceroute to 68.142.226.40 (68.142.226.40), 30 hops max, 38 byte packets 1 192.168.1.1 (192.168.1.1) 0.801 ms 0.749 ms 0.729 ms 2 67.69.27.57 (67.69.27.57) 1.898 ms 1.909 ms 1.894 ms 3 64.230.194.178 (64.230.194.178) 9.660 ms 14.352 ms 11.032 ms 4 64.230.233.81 (64.230.233.81) 9.666 ms 10.382 ms 9.307 ms 5 64.230.222.21 (64.230.222.21) 10.266 ms 10.114 ms 10.300 ms 6 206.108.107.230 (206.108.107.230) 10.169 ms 9.392 ms 10.494 ms 7 209.58.25.69 (209.58.25.69) 10.458 ms 9.367 ms 10.942 ms 8 216.6.57.33 (216.6.57.33) 28.928 ms 29.757 ms 30.315 ms 9 216.6.57.42 (216.6.57.42) 36.011 ms 35.677 ms 34.488 ms 10 63.243.149.110 (63.243.149.110) 38.094 ms 33.761 ms 35.160 ms 11 216.115.96.189 (216.115.96.189) 34.285 ms 216.115.96.173 (216.115.96.173) 40.339 ms 216.115.96.193 (216.115.96.193) 34.594 ms 12 206.190.33.95 (206.190.33.95) 36.994 ms 206.190.33.93 (206.190.33.93) 36.402 ms 206.190.33.89 (206.190.33.89) 32.584 ms 13 68.142.226.40 (68.142.226.40) 36.595 ms 35.023 ms 35.818 ms
The following example performs a traceroute, specifying the source interface by number:
EWC.extremenetworks.com# traceroute source-interface number 2 192.168.3.12 traceroute to 192.168.3.12 (192.168.3.12) from 10.1.0.1, 30 hops max, 38 byte pa ckets 1 ac_esa_port_0 (10.1.0.1) 3001.190 ms !H 3000.825 ms !H 3000.581 ms !H
