show
Use the show command to display AP information. The show command is accessible from the ap:<serial> , all ap:defaults: contexts and professional-antenna contexts of the CLI.
show
Parameters
None
The following example displays 3935FCC AP information:
EWC.extremenetworks.com:ap:defaults:3935FCC# showssh enabled
poll_timeout 15
no client_session
no persistent
no bcast_disassoc
country United States
no lldp
led-mode normal
lbs-status enabled
secure-tunnel disable
ipmcast-assembly disabled
balanced-power enabled
The following example displays ap37xx information:
EWC.extremenetworks.com:ap:defaults:ap37xx# show
ssh enabled
poll_timeout 22
client_session
persistent
bcast_disassoc
country Ireland
no lldp
led-mode normal
lbs-status enabled
The following example displays information for the <serial> AP:
EWC.extremenetworks.com:ap:0500008043050236# show
host_name AP3620-0500008043050236
name 0500008043050236
desc
role ap
ap_env indoor
usedhcp
poll_timeout 15
client_session
no persistent
no bcast_disassoc
no vlanid
led-mode normal
wlan test both
lbs-status enabled
port-setting auto
tunnel-mtu 1500
ssh enabled
antennaleft No Antenna
antennamiddle No Antenna
antennaright No Antenna
The following example displays the load groups:
EWC.extremenetworks.com:ap:load-groups# show
Load Groups:
loadgroup1
loadgroup2
The following example displays the contents of the professional-antenna context:
EWC.extremenetworks.com:ap:1313254259510000:professional_antenna# show
Professional Antenna Install:
Antenna                      Type
Radio 1 Left Antenna Type    No Antenna
Radio 1 Middle Antenna Type  PRO-AI-DT05120 AG 5dBi 120deg 3f
Radio 1 Right Antenna Type   PRO-AI-DX02360 AG 2dBi Omni
Radio 2 Left Antenna Type    PRO-AI-DX02360 AG 2dBi Omni
Radio 2 Middle Antenna Type  PRO-AI-DX02360 AG 2dBi Omni
Radio 2 Right Antenna Type   PRO-AI-DX07025 AG 7dBi 27/30deg
