Use this command to enable or disable the ability to add a controller IP address and port to the redirection URL. The add-ip-port command is available in the wlan:<WLAN-service-name>:auth:captiveportal context for external captive portal mode only.
enable | Enable adding a controller IP address and port to the redirection URL. |
disable | Disable adding a controller IP address and port to the redirection URL. This is the default. |
