Use the client_session command to enable users to maintain client sessions in the event of a poll failure. Use the no form of the command to disable the feature. The client_session command is accessible from the ap:<serial> and all ap:defaults contexts of the CLI.
After you run the client_session command, run the apply command to implement the change in client session.
None
The following example enables user client sessions:
EWC.extremenetworks.com:ap:defaults:3935FCC# client_session
Print
                        this page
Email this topic
Feedback
