Use the classification command to enable or disable interference classification on this profile. The classification command is accessible from the mitigator:scprof:<named scan profile> context and the mitigator:gsprof:<named guardian scan profile> context of the CLI.
After you run the classification command, run the apply command to implement the change.
| enable | Enables interference classification on this profile |
| disable | Disables interference classification on this profile |
The following example enables classification:
EWC.extremenetworks.com:mitigator:scprof:scp_name# classification enable EWC.extremenetworks.com:mitigator:scprof:scp_name# apply
Print
                        this page
Email this topic
Feedback
