Use the netmask command to optionally configure a netmask for a B@AC or B@AP topology. The netmask command is available from the topology:<named-topology> context of the CLI for b@ap or b@ac topologies with disabled l3presence. If configured, the netmask will be used in the RADIUS Accounting Framed-IP-Netmask attribute (assuming RADIUS accounting is using this topology).
| netmask | Specifies the netmask in dotted-decimal notation. |
| CIDR | Specifies the number of bits in the netmask that make up the network ID. |
| none | Specifies that no netmask is configured. |
The following example sets the netmask for the bap topology to 24 (equivalent to netmask 255.255.255.0):
EWC.extremenetworks.com:topology:bap:l3# netmask 24
Print
this page
Email this topic
Feedback
