Use the remoteable command to enable or disable the SSID advertisement to the mobility domain. The remoteable command is accessible from the wlan:<WLAN-service-name> context of the CLI.
After you run the remoteable command, run the apply command to implement the changes.
| enable | disable | Enables or disables the SSID advertisement to the mobility domain. |
The following example enables the SSID advertisement for the CNL-7-CP WLANS:
EWC.extremenetworks.com:wlans:CNL-7-CP# remoteable enable EWC.extremenetworks.com:wlans:CNL-7-CP# apply EWC.extremenetworks.com:wlans:CNL-7-CP# show remoteable Remote Service: enable
Print
                        this page
Email this topic
Feedback
