Use the sync command to enable or disable automatic synchronization of this WLAN service across paired Wireless Appliances. The sync command is accessible from the wlan:<WLAN-service-name> context of the CLI.
After you run the sync command, run the apply command to implement the changes.
| enable | disable | Enables or disables automatic synchronization of this WLAN service across paired Wireless Appliances. |
The following example enables synchronization for this WLAN service:
EWC.extremenetworks.com:wlans:test# sync enable EWC.extremenetworks.com:wlans:test# apply EWC.extremenetworks.com:wlans:test# show sync Synchronize: enable
Print
this page
Email this topic
Feedback
