Use the egress-filtering command to enable or disable egress filtering on this WLAN service. The egress-filtering command is accessible from the wlans:<WLAN-service-name> context of the CLI.
After you run the egress-filtering command, run the apply command to implement the changes.
enable | Enables filtering on this WLAN service. |
disable | Disables filtering on this WLAN service. |
The following example enables filtering on the test WLAN:
EWC.extremenetworks.com:wlans:test# egress-filtering enable EWC.extremenetworks.com:wlans:test# apply EWC.extremenetworks.com:wlans:test# show Egress Filtering: enable
