Use the server-ip command to set the location-based server IP address. The server-ip command is accessible from the lbs context of the CLI.
| A.B.C.D | Specifies the IP address of the location-based server. |
This command is visible only if a location-based service has been enabled via the service command.
The default IP address is 0.0.0.0.
The following example sets the IP address of the AeroScout server to 192.168.3.100:
EWC.extremenetworks.com:lbs# service aeroscout EWC.extremenetworks.com:lbs# server-ip 192.168.3.100
Print
                        this page
Email this topic
Feedback
