Use the name command in the vnsmode:<named-VNS> context to change the name of the current VNS.
After you run the name command, run the apply command to implement the changes.
| VNS-name | Specifies the new name for the current VNS. |
The following example changes the name of VNS1 to VNS2, then uses the show command to display information for the current VNS, including its name:
EWC.extremenetworks.com:vnsmode:VNS1# name VNS2 EWC.extremenetworks.com:vnsmode:VNS1# apply EWC.extremenetworks.com:vnsmode:VNS1# show WLANS service: test Non-authenticated: p4 Authenticated: same as non-authenticated Restrict available role set: disable Enable status: enable Synchronize: disable Name: VNS2
Print
this page
Email this topic
Feedback
