Use the show ap command to show the configuration information of Wireless APs connected to the Wireless Appliance.
Use ap37xx to modify ap37xx and W78xC ap defaults settings.
| access | Displays the status of the Wireless APs. |
| registration | Displays the registration information. |
| version | Displays the software version installed on Wireless APs. |
| load-groups | Displays the configured load groups. |
| defaults | Displays the Dynamic Radio Frequency management settings. |
| config | Displays the configured values of the Wireless AP. |
Specific model number that depends
on the license of the controller. For example, 3935FCC
APs. This can be any of the following models with the specific regulatory
domain license:
| ap37xx | Displays the configured values of the 37xx access point. |
| ap38xx | Displays the configured values of the 38xx access point. |
| ap3801 | Displays the configured values of the 3801 access point. |
| ap_serial | Specifies the serial number of a specific Wireless AP. |
| clients | Displays the clients connected to the Wireless AP. |
| static_config | Displays the static configuration values. |
| config | Displays the configured values for the Wireless AP. |
| radio1 | Displays the Wireless AP‘s radio 1 settings. |
| radio2 | Displays the Wireless AP‘s radio 2 settings. |
| version | Displays the software version and hardware type of the Wireless AP. |
| professional_antenna | Displays the professional_antenna settings. |
EWC.extremenetworks.com# show ap serial 000000VPC1553827 W788C_06 W788C-2-RJ45 serial 0000141600020802 3865e_13 AP3865e serial 12341770905A0000 3705i_01 AP3705i serial 12343567905A0000 3705i_02 AP3705i serial 13140663595A0000 3710i_03 AP3710i serial 13440720085E0000 3715i_04-05 AP3715i-1 serial 1404009608410000 3825e_16-17 AP3825e serial 1404013908410000 3825i_09-10 AP3825i serial 14160231085A0000 3825e_11-12 AP3825e serial 1450451508410000 3801i_07 AP3801i serial 1525D10061100000 3935e-ROW_14-15 AP3935e-ROW serial 1541D20040490000 3935i-ROW_18 AP3935i-ROW serial 1544Y-1001600000 3935i-ROW_19 AP3935i-ROW serial 2014180500000012 3805e_08 AP3805e
EWC.extremenetworks.com# show ap access 0122003880188015 LOCAL APPROVED 0409920201204003 LOCAL APPROVED 12343502905A0000 LOCAL APPROVED ACTIVE 1306032659480000 LOCAL APPROVED ACTIVE
EWC.extremenetworks.com# show ap registration security on dinterval 10 dretry 2 Cluster encryption: enable Cluster inter AP roam: enable Cluster shared secret: ********
EWC.extremenetworks.comshow ap defaults 3935FCC ssh enabled poll_timeout 15 no client_session no persistent no bcast_disassoc country United States no lldp led-mode normal lbs-status enabled secure-tunnel disable ipmcast-assembly disabled balanced-power enabled
EWC.extremenetworks.com# show ap 0409920201204003 clients
Client IP Client Protoc Radi BSS MAC SSID Auth Time User Roam
MAC ol o / Conn. ed
Priv
172.16.50. 00:40:9 g 2 00:0F:B CNL- EAP/ 0:21: test1 NO
250 6:AB:61 B:09:F6 220-14- WPA 14
:58 :A2 3-ssid
Total 1
show ap clients output, continued:
Policy Topolo RSS Avg. Bytes Packets UL Drop DL Drop DL Drop DL Lost
gy (dBm) Rate Sent/ Sent/ Rate Rate Buffer Retrie
(Mbps) Receive Received Packet Packet Packet s
Sent/ d d s/ s/ s/ Packet
Recvd Bytes Bytes Bytes s/
Bytes
CNL-220- CNL- -25 54.0/ 1212/ 297250/ 0/0 0/0 0/0 0/0
14-3- 220- 54.0 2047 279660
default 14-3
EWC.extremenetworks.com# show ap 0409920201204003 static_config Static IP Address: 10.205.0.11 Static Netmask: 255.255.255.0 Static Gateway: 10.205.0.2 AC IP: 10.205.0.1 AC Order: 1
EWC.extremenetworks.com# show ap 1111111111139351 config AP Serial Number: 1111111111139351 AP host name: AP3935i-1111111111139351 AP Name: 3935i Description: Active # of clients: 0 AP software version: 10.01.01.0123 Status: approved role : ap Home: local DHCP IP address: 0.0.0.0 DHCP NetMask: 0.0.0.0 DHCP Gateway: 0.0.0.0 Hardware Type: Wireless AP3935i-FCC Internal Wired MAC address: 00:00:00:00:00:00
EWC.extremenetworks.com# show ap 1111111111139351 radio1 dtim 5 beaconp 100 nonUnicastQuota 100 rts 2346 frag 2346 domain fjdkfj.jfadkl tx_max_power 10 dBm radio mode anac no atpc minbrate 6 n_chlwidth auto current channel None last requested channel 40: (5180,[5200],5220,5240) n_guardinterval short n_pmode auto n_ptype cts only n_pbthreshold 50 no n_aggr_msdu n_aggr_mpdu n_aggr_mpdu_max 1048575 n_aggr_mpdu_max_subframes 30 n_addba_support probe-suppression disable admin-mode on ldpc enable stbc enable txbf mu_mimo optimized-mcast disable mcast-adaptable disable mcast2ucast disabled current_power: 0 dcs mode monitor channel_plan all-non-dfs noise_threshold -80 occupancy_threshold 100 update_period 5
EWC.extremenetworks.com# show ap 1111111111139351 radio2 dtim 5 beaconp 100 nonUnicastQuota 100 rts 2346 frag 2346 domain MyDomain preamble long tx_max_power 13 dBm pmode auto prate 11 ptype cts only radio mode bgn no atpc minbrate 1 n_chlwidth auto current channel None last requested channel Auto n_guardinterval short n_pmode auto n_ptype cts only n_pbthreshold 50 no n_aggr_msdu n_aggr_mpdu n_aggr_mpdu_max 65535 n_aggr_mpdu_max_subframes 30 no n_addba_support probe-suppression disable admin-mode on ldpc enable stbc enable optimized-mcast disable mcast-adaptable disable mcast2ucast disabled current_power: 0 dcs mode monitor channel_plan auto noise_threshold -80 occupancy_threshold 100 update_period 5 interference-wait-time 10 interference-event-type none
EWC.extremenetworks.com# show ap 1111111111139351 version Software version: 10.01.01.0123 Hardware Type: Wireless AP3935i-FCC Internal
EWC.extremenetworks.com# show ap version Serial: 1111111111139351 Version: 10.01.01.0123 Serial: 1111111111138251 Version: 10.01.01.0123 Serial: 13310619085D0000 Version: 10.01.01.0123 Serial: 1111111111137152 Version: 10.01.01.0123
EWC.extremenetworks.com# show ap load-groups Load Groups: Name: CNL_201_Radio-001 Type : radio Name: CNL_201_Client_Balancing-002 Type : client Name: CNL_201_Radio-008 Type : radio Name: Radio-001 Type : radio Name: CNL_201_Client_Balancing-001 Type : client
