Use the guestportal-admin-timeout command to configure the time after which the web sessions of guest administrator users (guestportal user type) times out. The guestportal-admin-timeout command is accessible from the web context of the CLI.
After you have run the guestportal-admin-timeout command, run the apply command to implement the changes.
hh:mm | Specifies time in hh:mm format — hours:minutes , range 1 minute to 7 days. |
mm | Specifies time in number of minutes. |
The following example sets the web session timeout to one hour and 30 minutes:
EWC.extremenetworks.com:web# guestportal-admin-timeout 01:30
The following example sets the web session timeout to 30 minutes:
EWC.extremenetworks.com:web# guestportal-admin-timeout 30
