Use the nasid command to identify the Network Access Server (NAS) to be used with the RADIUS server being configured. The nasid command is accessible from the wlans:<WLAN-service-name>:auth context of the CLI.
After you run the nasid command, run the apply command to implement the changes.
| string | Specify the ID for the NAS |
| vnsname | Specifies that the VNS name should be used for the NAS ID |
The NAS ID defaults to the VNS name if this command is not used to specify a NAS ID.
You must be in RADIUS server configuration mode for the nasid command to be available. Use the config command to enter RADIUS server configuration mode. For more information, see config.
The following example sets the NAS ID for this RADIUS server configuration to the VNS name for the cnl-AAA WLANS auth context:
EWC.extremenetworks.com:wlans:cnl-AAA:auth# nasid vnsname EWC.extremenetworks.com:wlans:cnl-AAA:auth# apply EWC.extremenetworks.com:wlans:cnl-AAA:auth# show nasid NAS identifier: Use VNS name
Print
this page
Email this topic
Feedback
