Use the domain command to configure a domain name. The domain command is available from the topology:<named-topology>:l3:dhcp context of the CLI for b@ac, physical, and routed topologies. This command is visible only when mode is set to local. See mode.
| domain name | Specifies the domain name or an IPv4 address. |
| none | Clears the domain name. |
The following example sets the domain name as my-domain:
EWC.extremenetworks.com:topology:test:l3:dhcp# mode local EWC.extremenetworks.com:topology:test:l3:dhcp# domain my-domain
Print
this page
Email this topic
Feedback
