Use the aplist command to modify the list of the Wireless APs that are part of the scan profile. Use the no form of the command to delete the Wireless APs from the list. The aplist command is accessible from the mitigator:scprof:<named scan profile> context, and the mitigator:gsprof:<named guardian scan profile> context of the CLI.
After you run the aplist command, run the apply command to implement the change.
| add | delete | Add or delete the (following) APs from the scan profile. If you omit these options, by default all APs in the scan profile are replaced with the APs listed in this command. |
| serial[, serial]* | Specifies the Wireless AP by their serial numbers that are to be added to the scan profile. They can be added or deleted individually, or listed as a comma and space separated list. |
Use the add or delete option to make changes to an existing scan profile AP list. You can replace the APs listed in the scan profile by omitting the add or delete option, and listing the APs you want.
The following example adds a Wireless AP with the serial number 500006072051354 to the scan profile:
EWC.extremenetworks.com:mitigator:scprof:scp_name# aplist add 500006072051354 EWC.extremenetworks.com:mitigator:scprof:scp_name# apply
The following example deletes a Wireless AP with the serial number 500006072051354 from the scan profile:
EWC.extremenetworks.com:mitigator:scprof:scp_name# aplist delete 500006072051354 EWC.extremenetworks.com:mitigator:scprof:scp_name# apply
The following example replaces the Wireless APs in the scan profile with those with the following serial numbers: 500006072051354, 500005380080168, and 0500006072051427:
EWC.extremenetworks.com:mitigator:scprof:scp_name# aplist 500006072051354, 0500006072051427, 500005380080168 EWC.extremenetworks.com:mitigator:scprof:scp_name# apply
