Use the port command to enable or disable the port administration status of the layer 2 port in this context. The port command is accessible from the l2ports:<named-LAG-port> context.
| enable | Enables the administration status for the port for this context. |
| disable | Disables the administration status for the port for this context. |
The following example enables the administration status of lag-member ports in an l2ports:lag1# context:
EWC.extremenetworks.com# l2ports EWC.extremenetworks.com:l2ports# lag1 EWC.extremenetworks.com:l2ports:lag1# port enable EWC.extremenetworks.com:l2ports:lag1# apply EWC.extremenetworks.com:l2ports:lag1# show Admin: enable EWC.extremenetworks.com:l2ports:lag1#
Print
this page
Email this topic
Feedback
