show report channel_inspectorUse the show report channel_inspector command to view the Channel Inspector Report. The show report channel_inspector command is accessible from the root context of the CLI.
| ap_serial | Identifies the AP that the report is associated with. |
| radio 1 | radio 2 | Identifies the radio that the report is associated with. |
| channel_index | Specifies the channel index to view channel details. The first time you run the show report channel_inspector command, do not include channel_index. |
Run show report channel_inspector command without <channel_index> first. The report displays with a channel index for each channel in the report. To display details for a specific channel, run show report channel_inspector command a second time including the <channel_index> number for the channel that you want details. Details for the specified channel index are displayed.
The following example shows the Channel Inspector Report for radio 1 of a single AP. Each channel has an index value.
EWC.extremenetworks.com show report channel_inspector 1541D10030050000 radio1
Channel Index Ranking Frequency Noise(dBm) Overlap Co-Channel Adjacent APs
0 0 36:([5180],5200) -106 30 39 43
1 0 44: ([5220],5240) -106 38 34 26
To view channel details for Channel Index 0, run the show report channel_inspector command again, including the channel_index value 0. The following is example output.
EWC.extremenetworks.com show report channel_inspector 1541D10030050000 radio1 0
Interference Frequency RSS BSSID AP Name
Type
Overlapping 40: (5200) -65 20:B3:99:AE:C6:70 AP3965e1541D10030050000
Overlapping 40: (5200) -71 20:B3:99:1E:6F:01 AP3965e1541D10030050000
Overlapping 40: (5180,[5200]) -65 00:1F:45:FF:F2:76 AP3965e1541D10030050000
Overlapping 40: (5180,[5200]) -66 00:1F:45:FF:F2:70 AP3965e1541D10030050000
Overlapping 40: (5180,[5200]) -66 00:1F:45:FF:F2:71 AP3965e1541D10030050000
Overlapping 40: (5180,[5200]) -66 00:1F:45:FF:F2:73 AP3965e1541D10030050000
Overlapping 40: (5180,[5200]) -66 00:1F:45:FF:F2:74 AP3965e1541D10030050000
Overlapping 40: (5180,[5200]) -66 00:1F:45:FF:F2:75 AP3965e1541D10030050000
Overlapping 40: (5180,[5200]) -67 00:1F:45:FF:F2:72 AP3965e1541D10030050000
Overlapping 40: (5180,[5200]) -69 00:1F:45:FF:F2:77 AP3965e1541D10030050000
Overlapping 40: (5180,[5200]) -70 20:B3:99:A5:DF:81 AP3965e1541D10030050000
Overlapping 40: (5180,[5200]) -70 20:B3:99:A5:DF:82 AP3965e1541D10030050000
