Use this command to select a password character set. The pwd-charset command is available in the wlan:<WLAN-service-name>:auth:captiveportal context.
| greek | Determines that the greek character set is used when generating a password pattern. |
| cyrilic | Determines that the cyrilic character set is used when generating a password pattern. |
| latin | Determines that the latin character set is used when generating a password pattern. |
The guest portal WLAN must be configured.
Print
this page
Email this topic
Feedback
