Use the apfilters command to enter the role:<named-role>:apfilters context for the configuring of AP custom filters. AP custom filters are applied at the AP. The apfilters command is accessible from the role:<named-role> context. Execute the ulfilterap enable command and the apcustom enable command before the apfilters command is visible.
The following commands are available in the role:<named-role>:apfilters context.
None.
The apply custom filters to AP feature must be enabled using the apcustom enable command for the apfilters command to be visible in the CLI.
The following example enters the role:<named-role>:apfilters context for the p1 <named-role>:
EWC.extremenetworks.com:role:p1# ulfilterap enable EWC.extremenetworks.com:role:p1# apcustom enable EWC.extremenetworks.com:role:p1# apfilters EWC.extremenetworks.com:role:p1:apfilters#
