Use the 11k-beacon-rep command to enable and disable 802.11k beacon reports on AP 37xx and 38xx appliances. The 11k-beacon-rep command is accessible from the wlan:<WLAN-service-name>:rf context of the CLI.
The 11k-beacon-rep command is only available after the 11k-support command is enabled.| enable | disable | Enables or disables 802.11k beacon reports on AP 37xx and 38xx appliances. |
The following example enables 802.11k beacon reports on the WLAN service:
EWC.extremenetworks.com:wlans:AZ-723-WLAN1:rf# 11k-beacon-rep enable
Print
this page
Email this topic
Feedback
