Use the update_period command to set the DCS update period, during which the Wireless AP averages the DCS noise threshold and DCS channel occupancy threshold measurements. If either one of these thresholds is exceeded, the Wireless AP triggers ACS. The update_period command is accessible from all radio dcs contexts of the CLI.
period | Specifies the time period, measured in minutes, during which the Wireless AP averages the DCS noise threshold and DCS channel occupancy threshold measurements. If either one of these thresholds is exceeded, then the Wireless AP triggers ACS. Range is 1 to 15 minutes, or 0 to disable. |
The following example sets the DCS update period to 12 minutes:
EWC.extremenetworks.com:ap:defaults:ap37xx:radio1:dcs# update_period 12
The following example disables the DCS update period:
EWC.extremenetworks.com:ap:defaults:ap37xx:radio1:dcs# update_period 0
