Use the acfilters command to enter the role:<named-role>:acfilters context for the configuring of AC filters. AC filter rules are applied at the controller. The acfilters command is accessible from within the role:<named-role> context.
AC filtering is not available when the associated topology is configured for Bridge at AP. AC filtering is available when the associated topology is set to either Bridge at AC or Routed.
The following commands are available in the role:<named-role>:acfilters context.
None.
The “no-change” filter setting must be disabled by the access-control command for the acfilters command to be visible in the CLI.
The following example enters the role:<named-role>:acfilters context for the Auth <named-role>:
EWC.extremenetworks.com:role:Auth# acfilters EWC.extremenetworks.com:role:Auth:acfilters#
