Use the ulfilterap command to enable filtering on the AP. The ulfilterap command is accessible from the role:<named-role> context.
| enable | disable | Provides for the enabling or disabling of filtering on the AP for this role:<named-role> context. |
When filtering is enabled on the AP, wireless APs obtain client filter information from the Wireless Appliance. Filter rules defined on the controller are applied by wireless APs. In addition, direct inter-Wireless AP communication allows Wireless APs to exchange client filter information as clients roam from one Wireless AP to another.
The filter setting feature must be disabled using the filter disable command for the apfilters command to be visible in the CLI.
See apcustom to apply custom filters for the AP.
The following example enables filtering on the AP for this role:p1 context:
EWC.extremenetworks.com:role:p1# ulfilterap enable EWC.extremenetworks.com:role:p1#
Print
this page
Email this topic
Feedback
