Use the apfilters command to enter the vnsmode:default-role:apfilters context for the configuring of AP custom filters. AP custom filters are applied at the AP. Default-role AP custom filters are applied when no AP custom filters are configured for role applied at the AP. The apfilters command is accessible from the vnsmode:default-role context.
This command is not visible in the CLI if you execute the apcustom disable command.
The following commands are available in the vnsmode:default-role:apfilters context:
Print
this page
Email this topic
Feedback
