Use the type command to indicate the data types to backup.
configuration | Indicates that configuration files will be backed up |
cdrs | Indicates that call detail records will be backed up |
all | Indicates that all configuration, call detail records, log files, audit files, and rogue files will be backed up |
logs | Indicates that log files will be backed up |
audit | Indicates that audit files will be backed up |
The following example indicates that audit files are to be backed up:
EWC.extremenetworks.com:schedule_backup# type audit
