Use the netflow command to enable or disable NetFlow on the named WLAN. The netflow command is accessible from the wlans:<named-wlan> context of the CLI.
| enable | disable | Enables or disables NetFlow on the named WLAN. |
The following example enables NetFlow on the HT_BR WLAN:
EWC.extremenetworks.com:wlans:HT_BR# netflow enable
Print
this page
Email this topic
Feedback
