Use the dls command to enable or disable DLS (HiPath Deployment Services). The dls command is available from the topology:<named-topology>:l3:dhcp context of the CLI for b@ac and routed topologies. This command is visible only when mode is set to local. See mode.
After you run the dls command, run the apply command to implement the changes.
| enable | Enables DLS. |
| disable | Disables DLS. |
The following example enables DLS:
EWC.extremenetworks.com:topology:test:l3:dhcp# mode local EWC.extremenetworks.com:topology:test:l3:dhcp# dls enable
The following example disables DLS:
EWC.extremenetworks.com:topology:test:l3:dhcp# mode local EWC.extremenetworks.com:topology:test:l3:dhcp# dls disable
Print
this page
Email this topic
Feedback
