txbf
Use the
txbf command to enable or disable the 11n advanced TXBF feature. The
txbf command is accessible from the ap:defaults: context and the
ap:<serial> radio contexts for the following AP models:
- ap37xx
- ap38xx (radio 2)
- ap3801 (radio 2)
- ap3935 (FCC and ROW, radio 1)
- ap3965 (FCC and ROW, radio 1)
- ap3912 (FCC, radio 1)
The available parameters depend on the AP type and the radio.
txbf enable | disable or txbf mu_mimo enable | disable for AP3935
and AP3965 on Radio 1.
Usage
When TXBF is enabled, antenna selection must be left-middle-right.
Parameters
| enable |
Enables the 11n advanced TXBF feature. |
| disable |
Disables the 11n advanced TXBF feature. |
| mu_mimo |
Sets TxBF to MU-MIMO. |
The following example enables TXBF on radio1:
EWC.extremenetworks.com:ap:defaults:ap37xx:radio1# txbf enable
