Use the 11h-power-reduction command to enable or disable automatic power reduction of transmissions using the 802.11h standard. The 11h-power-reduction command is accessible from the wlan:<WLAN-service-name>:rf context of the CLI.
After you run the 11h-power-reduction command, run the apply command to implement the changes.
| enable | disable | Enables or disables automatic power reduction of transmissions using the 802.11h standard. |
The following example enables the power reduction feature on the WLAN service:
EWC.extremenetworks.com:wlans:test:rf# 11h-power-reduction enable EWC.extremenetworks.com:wlans:test:rf# apply EWC.extremenetworks.com:wlans:test:rf# show 11h-power-reduction Apply power reduction to 11h clients: enable
Print
this page
Email this topic
Feedback
