Use the ping command to ping an IP address. The ping command accepts an optional parameter that specifies the source ip address to be used by the command. If this optional source is provided, ping uses the IP address of the specified interface as the source IP address.
| source-interface name name | number id | Specifies the address of the source interface you want to send pings from, either by interface name or ID. |
| IP Address | Specifies the IP address you want to ping. The IP address can be either IPv4 (A.B.C.D) or IPv6 (A:B:C:D:E:F:G:H) format. |
You can identify the source IP using its interface name or, for short, the identifier returned by the show topology l3 command. Interface name is the name of any topology with L3 configuration (Physical, Admin, B@AC or Routed).
EWC.extremenetworks.com# ping 192.168.1.32 PING 192.168.1.32 (192.168.1.32) from 192.168.1.38 : 56(84) bytes of data. 64 bytes from 192.168.1.32: icmp_seq=1 ttl=64 time=0.423 ms 64 bytes from 192.168.1.32: icmp_seq=2 ttl=64 time=0.218 ms 64 bytes from 192.168.1.32: icmp_seq=3 ttl=64 time=0.204 ms --- 192.168.1.32 ping statistics --- 3 packets transmitted, 3 received, 0% loss, time 2013ms rtt min/avg/max/mdev = 0.204/0.281/0.423/0.101 ms
EWC.extremenetworks.com# show topology l3 Name Mode L3:IP 1:Admin admin 192.168.4.37 2:esa0 physical 10.0.0.1 3:esal Physical 10.0.1.1 4:Extreme-37Topology b@ac 10.10.1.1
EWC.extremenetworks.com# ping source-interface name esa1 192.168.4.37 PING 192.168.4.37 (192.168.4.37) from 10.0.1.1 : 56(84) bytes of data. 64 bytes from 192.168.4.37: icmp_seq=1 ttl=64 time=0.042 ms 64 bytes from 192.168.4.37: icmp_seq=2 ttl=64 time=0.037 ms 64 bytes from 192.168.4.37: icmp_seq=3 ttl=64 time=0.039 ms --- 192.168.4.37 ping statistics --- 3 packets transmitted, 3 received, 0% packet loss, time 1999ms rtt min/avg/max/mdev = 0.037/0.039/0.042/0.005 ms
