delete
Use the delete command to delete a topology object. The delete command is accessible from the topology context of the CLI.
You cannot delete the Admin topology. Also, you cannot delete a topology that is in use by a policy.
delete topology name
Parameters
topology name Specifies the name of the topology to delete.
The following example deletes the topology named test:
EWC.extremenetworks.com:topology# delete test
