guestportalprefix
Use the guestportalprefix command, within context wlan:<WLAN-service-name>:auth:captiveportal, to configure the user ID prefix for the guest portal access account.
After you run the guestportalprefix command, you must run the apply command to implement the changes.
guestportalprefix prefix
Parameters
prefix Specifies the maximum number of hours for the session time of the guestportal access account
Usage
The guestportal authentication mode must be set for this command to be available. For more information, see mode.
The following example sets the guest portal prefix to the string “TEST”:
EWC.extremenetworks.com:wlans:CNL-CP:auth:captiveportal# guestportalprefix TEST
EWC.extremenetworks.com:wlans:CNL-CP:auth:captiveportal# apply
EWC.extremenetworks.com:wlans:CNL-CP:auth:captiveportal# show guestportalprefix
