custom-app-listUse the custom-app-list command to configure a custom application list for ExtremeWireless application visibility. The custom application list includes the application name (or hostname), group, and matching pattern. The custom-app-list command is accessible from within the root: vnsmode: custom-app context.
| add | Add a custom application to the list of possible applications available for ExtremeWireless application visibility. |
| delete | Remove a custom application from the list of possible applications available for ExtremeWireless application visibility. |
| group group name | Indicates the name of the group name to which the custom application belongs. For more information, see Usage. |
| name app name | Indicates the name of the custom application. |
| hostname app name | Indicates that the custom application type is hostname. The (L7) custom application authenticates based on a user defined IP/subnet parameter in the Layer 3 configuration. This configuration allows mobile clients to authenticate using credentials from a specific host. For more information, see the ExtremeWireless User Guide. |
| pattern matching pattern | Indicates the matching pattern for the custom application. Pattern matching is an element of deep packet inspection used as part of network security. |
| sequence id | Identifies the sequence of the APP in the database. |
| name | Identifies the name of the APP in the database. |
The custom-app-list command is issued from the custom-app context. The group names are pre-defined standard Extreme Application Analytics™ signature groups. The group names are case-sensitive.
To see a list of pre-defined group names, see show app group.
EWC.extremenetworks.com:vnsmode:custom-app# custom-app-list add group Advertising name Letv pattern letv.com
The following example configures the application name type as hostname.
EWC.extremenetworks.com:vnsmode:custom-app# custom-app-list add group Advertising hostname Letv pattern letv.com
