Use this command to select a password pattern. The pwd-pattern-select command is available in the wlan:<WLAN-service-name>:auth:captiveportal context.
| custom | Generate a custom password pattern. Allows the user to type a password pattern in the Pattern field or to use the key pad. |
| phone-number | Use the predefined phone-number pattern to generate a password pattern. |
| random | Use the predefined random pattern to generate a password pattern. |
| postal-code | Use the predefined postal-code pattern to generate a password pattern. |
| two-words | Use the predefined two-word pattern to generate a password pattern. |
The guest portal WLAN must be configured.
Print
this page
Email this topic
Feedback
